DiamondFinish Clear Used To Paint Engine Covers
Customer Feedback.
"I used the DiamondFinish Clear on several projects that I airbrushed to include engine covers and other under hood items. The clear was easy to spray with my spray gun when reduced with the #1 Thinner. I will use the product again without hesitation. Lays down evenly."
  • 7 years later...
anyone know how to put a light tint into the diamond clear, i am using transparent fishing lures and need to change the color of the body slightly, then i will hand paint slightly, then dip into the clear coat several times
thanks
sac
  • Author
You can use urethane grade tints with DiamondFinish Clear which should be free of moisture. Best practice is to only mix what you need as the pot life might be diminished once you add the tints.
