Motor Coater temperature cure?
I couldn't find any information, but also didn't want to assume… I've used Engine paints in the past that don't full cure until they are heated by the heat of a running engine. I wish to use Motor Coater as a top coat for a cast iron base because of the pigment choices available. Knowing this base will never get engine temp hot, will the paint still cure properly if used as a top coat?
Motor Coater will fully cured without exposure to elevated temperatures. Please feel free to check out the complete directions for Motor Coater. Please let us know if that helps and if you have any additional questions.
