Painting BBQ Pits is a very common application for XTC (http://www.kbs-coatings.com/Xtreme-Temperature-Coating.html). Because you are dealing with a surface that has a great potential to rust, I would recommend priming it with the KBS Hi-Temp Zinc Primer (http://www.kbs-coatings.com/hi-temp-primer.html) before you apply 1-2 coats of KBS Hi-Temp.
The harmful fumes should be evacuated after the the temperature curing as described in the directions.
You can find the Hi-Temp Directions here: http://www.kbs-coatings.com/hi-temp-info.html
