fision inder KBS Hi-Temp Paint
Can I use Fusion as primer for KBS Hi Temp paint in a non hi temperature application? This is because I will get some Cast Iron Grey Hi-Temp paint for my exhaust pipes and then would like to use same color on engine cases. Then I am quessing I should use Hi-temp zinc primer on the exhaust pipes.
