Hi, I have a 99% solid 500gal diesel tank.
I just cleaned the tank to check for any pits on the bottom
where water was laying. There are several shallow on one end in a area on the bottom center line. Can I coat the tank partially on the bottom ~ 12" off either side of the center line?
~1 gal of KBS?
My concern is if the tank isn't completely encapsulated with KBS,
the fuel will ge behind the coating an cause failure.
Any info, advice, appreciated. Thanks
  • 12 years later...
  • KBS Coatings changed the title to Partially coating a 500 gal diesel tank
