April 6, 200818 yr comment_1606 I was wondering if you can or if any has used this system to do the inside of a frame. I'm restoring a jeep and didn't know if you can clean the inside of the frame properly to do this? If so, can you explain the process. Any help is appreciated. thanks Link to comment https://success.kbs-coatings.com/topic/975-frame-question/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 6, 200818 yr Author comment_1608 Clean the inside as best you can using the KBS Klean .. possibly with the aid of a Pressure Washer. Etch the inside with RustBlast the best that you can. Shoot a couple coats of RustSeal in there. We like to use the Underseal Gun. You can find the UnderSeal Gun HERE. Please let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/975-frame-question/#findComment-1608 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
