Motor Coater - Picture of Easy-To-Apply Engine Paint
As you can see, Motor Coater is formulated to make it easy to achieve stunning, professional-looking results when painting you engine.
Motor Coater colors are an exact match for the original color offering a rich, deep factory finish.
Motor Coater is very durable protecting your engine from chips, chemicals, and heat.
Motor Coater features advanced resin technology for heat dissipation and gloss retention.
Motor Coater is an incredible exterior grade coating that is UV stable and will not discolor, chalk, or fade when exposed to sunlight and the elements.
Motor Coater resists temperatures up to 500F intermittently and produces a professional finish that won't blister, flake, crack, or peel.
Learn More about Motor Coater here -> https://www.kbs-coatings.com/motor-coater
