The Shutz Underseal gun just has 45-150psi on the box.  What is the recommended pressure for spraying Undercoater?  What things should I be looking for when fine tuning the pressure from the recommendation?
Do you have any data for SCFM requirements for the Shutz gun?  Just want to make sure my compressor can keep up.
You will spray KBS UnderCoat with the spray tip on the KBS Schutz Gun.
The KBS Schutz Gun: Air Flow Consumption: 13.5 SCFM
You will start at 45PSI and then adjust based upon the texture desired. Fine tuning the pressure with KBS UnderCoat is all about the texture desired. More pressure is smoother texture.
