KBS Coatings Posted August 17, 2020 Report Share Posted August 17, 2020 The Frame Coater Kit is a quart size 3-Step System Kit that includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage. You get Top Quality Protection at a tremendous value! Detailed instructions included. KBS Coatings’ 3 Step System of RustSeal (a rust preventive coatings), KBS Klean (an industrial strength water-based cleaner / degreaser) and KBS RustBlast (a powerful rust remover / metal etch) is the most effective rust and corrosion prevention system available today.RustSeal is a paint or coating that chemically bonds to bare metal to form a permanent, moisture resistant finish that is flexible yet won't crack, chip, or peel. Because RustSeal is moisture-cured, this superior coating is made even stronger by continued exposure to moisture.RustSeal is also highly resistant to some of the most aggressive chemicals such as acids, alkalis, salts, abrasive materials, fertilizers, coal dusts, solvents, oils, and other refined petroleum products. Link to comment https://success.kbs-coatings.com/topic/2879-rust-prevention-on-a-truck-frame/ Share on other sites More sharing options...
