Tntdes Posted January 1, 2020 Report Share Posted January 1, 2020 Will be spraying the underbody while laying under the car on jackstands . Do your aerosol cans spray well when sprayed vertical? Thanks! Quote Link to comment https://success.kbs-coatings.com/topic/2749-rubberized-aerosol-spraying-vertical/ Share on other sites More sharing options...
KBS Coatings Posted January 2, 2020 Report Share Posted January 2, 2020 The aerosol cans spray better when up and down. Depending on how full the aerosol cans are (the fuller, the better) they can also spray when they are side to side. Please let us know if that helps and if you have any other questions. Quote Link to comment https://success.kbs-coatings.com/topic/2749-rubberized-aerosol-spraying-vertical/#findComment-4916 Share on other sites More sharing options...
