August 13, 201510 yr comment_3231 Can Fusion Self-Etching primer be used on/under Motor Coater Engine Enamel? Will it tolerate high heat? Or will it laminate? Link to comment https://success.kbs-coatings.com/topic/1819-fusion-under-motor-coater/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 13, 201510 yr comment_3236 Yes, you can use Fusion under Motor Coater. Fusion will withstand the same temperature range as the Motor Coater. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1819-fusion-under-motor-coater/#findComment-3236 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
