Shaggy Posted June 22, 2010 Report Share Posted June 22, 2010 I want to clear coat an aluminium and steel paneled vehicle so it looks like a bare metal finish. Can I use Diamond Finish clear coat for that. If so what surface prep is required? Quote Link to comment https://success.kbs-coatings.com/topic/1423-clear-coat-bare-metal-finish/ Share on other sites More sharing options...
KBS Jim Posted June 22, 2010 Report Share Posted June 22, 2010 I'd recommend you polish or buff the surface to your desired finish, then wash with a mild solution of 10 parts water to 1 part AquaKlean, rinse off with warm water, dry the surface down with a clean cloth & let air dry real well, then brush or spray on a couple coats of DiamondFinish. Thinning slightly with #1 Thinner helps allow the DF to flow out nicely especially during these warmer summer temps. Quote Link to comment https://success.kbs-coatings.com/topic/1423-clear-coat-bare-metal-finish/#findComment-2363 Share on other sites More sharing options...
