March 25, 201016 yr comment_2038 I shall be using your 3 Step Chassis coating kit on a race car we're restoring. more specifically we would like to use the KBS 3 Step kit around bits of the roll cage where theres light surface rust etc as it was never sprayed because the gun could not get into these tight spaces. could you give me some tips on how i could go about applying the KBS seal to these parts? the paint is not flaking, just where it starts turning into overspray to bare metal that has surface rust.. how would i go about cleaning that and prepping for the seal??? would i need to sand it down first? is there any negatives if the aquakleen or rust blast dries or if it doesnt get washed with water? also because this is inside the car i cant hose it down, how can i wash the aquakleen and rustblast?? Regards, J Link to comment https://success.kbs-coatings.com/topic/1407-3-step-chassis-coating-kit-question-on-applying/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 26, 201016 yr comment_2332 J, As far as rinsing off the AK & RB, just use a damp rag to wipe it down, that way you don't have to run water on the area. Yes I would sand donw those areas first. Can you brush on the RustSeal in those areas? Link to comment https://success.kbs-coatings.com/topic/1407-3-step-chassis-coating-kit-question-on-applying/#findComment-2332 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 28, 201016 yr Author comment_2335 Hi, yes i can get a brush into those areas.... Regards, Jim Link to comment https://success.kbs-coatings.com/topic/1407-3-step-chassis-coating-kit-question-on-applying/#findComment-2335 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 29, 201016 yr comment_2338 That would be best. Brush on the RustSeal in those tight areas. Link to comment https://success.kbs-coatings.com/topic/1407-3-step-chassis-coating-kit-question-on-applying/#findComment-2338 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
