September 30, 200917 yr comment_2008 I'm restoring a motorcycle that I think had a factory powder coated frame. I had planned to get the frame and several brackets sandblasted and powder coated, but now I'm wondering if the KBS Chassis Coater kit plus a Topcoat might produce similar results. It would save me some money and reduce the amount of work required in masking every threaded hole, plus I get that DIY satisfaction. What do you think? PS, I will be using the KBS Motorcycle Tank Sealer kit on the tank as well... Link to comment https://success.kbs-coatings.com/topic/1377-motorcycle-frame/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 8, 200917 yr comment_2256 I know of several people that have used the Chassis Coater Kit and a top coat of Blacktop on motorcycle frames and trailing arms. It would still be a good idea however to have the frame sand, or media blasted to remove all traces of factory paint or powder coat RustSeal will do a much better job if bonded to bare metal. Also You may still want to cover threaded holes with small rubber corks from the hardware store (about $.25 a pc) RustSeal and BlackTop is tough stuff, you may find yourself retapping threaded holes. The best thing about painting your frame with RustsealBlackTop, if it does pick up a few chips over time you can repair it. Good Luck repairing Powder Coating. Link to comment https://success.kbs-coatings.com/topic/1377-motorcycle-frame/#findComment-2256 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 8, 200917 yr Author comment_2257 I happened to be in an auto paint supplier yesterday and was talking to the proprietor and another guy who has restored a few bikes, and they convinced me that this approach would be better than powder coating for the same reason you mentioned - you can't repair it. Yes, the frame will be sand blasted. That was always my plan. I've ordered what I need from KBS and I'm looking forward to the job! Link to comment https://success.kbs-coatings.com/topic/1377-motorcycle-frame/#findComment-2257 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
