July 16, 200917 yr comment_1998 Is there any "unofficial" way to speed up the drying.. is this an epoxy based coating? Would heat help it? Link to comment https://success.kbs-coatings.com/topic/1367-speed-up-gas-tank-drying/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 16, 200917 yr comment_2243 No not really. This is not an epoxy and while heat will help to evaporate the solvent contained in the sealer, it will not help the resin cure and may in fact hinder the resin curing properly. My best advice would be for you to be patient and let the sealer cure slowly at ambient temperature out of direct heat or sunlight. Link to comment https://success.kbs-coatings.com/topic/1367-speed-up-gas-tank-drying/#findComment-2243 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
