Showing results for tags 'marine paint'.
How to Stop and Prevent Rust on Your Boat Trailer: A Complete Guide Boat trailers are constantly exposed to wet conditions, outdoor storage, and sometimes even salt water. These elements create the perfect environment for rust and corrosion to develop. Rust not only makes your trailer look bad but can also compromise its structural integrity. Left unchecked, it can lead to expensive repairs or even the need to replace the trailer. Boat Trailer Rust Prevention This guide will show you how to stop existing rust and prevent future rust on your boat trailer using the KBS Coatings Ultimate Frame Coater Kit, which includes KBS Klean, RustBlast, RustSeal and Cavity Coater. KBS Top Coater will be used for the final finish. Following these steps will ensure your trailer stays protected and your investment is preserved. How Does the KBS Coatings Ultimate Frame Coater Kit Work? The KBS Coatings Ultimate Frame Coater Kit and KBS Top Coater provide a comprehensive solution for boat trailer rust prevention and finish restoration. Here’s how they work together: KBS Klean: Degreases and cleans surfaces, ensuring the trailer is free of contaminants. RustBlast: Neutralizes existing rust and prevents further oxidation. RustSeal: Provides a long-lasting, strong, protective barrier against rust and corrosion. Cavity Coater Aerosol and Spray Wand: Provides self-healing film which offers incredible rust protection in hard-to-reach areas. Top Coater: Top coats RustSeal for UV protection and a smooth, durable finish. Using these products streamlines the entire process, making it easier to remove rust from a boat trailer and protect it for years to come. How Do I Remove Rust from a Boat Trailer? When it comes to removing rust from a boat trailer, the key is to neutralize the existing rust before it spreads. Using the KBS Coatings Ultimate Frame Coater Kit, this process is straightforward: 1. Remove Loose Rust and Paint Use a wire brush, 320 grit sandpaper, or sandblasting. Note: Sandblasting offers the fastest and most thorough way to completely remove rust. When sandblasting, RustBlast isn’t needed; RustSeal can be directly applied to newly sandblasted metal surfaces that have been handled with gloved hands. No preparation other than blowing off loose dust is required. Proceed to the “How to Apply RustSeal” section after sandblasting. Lightly scuff any well-adhered original paint with 320-grit sandpaper before proceeding. 2. Clean the Trailer with KBS Klean Thoroughly wash all areas of the trailer to be treated using KBS Klean, a powerful degreaser and cleaner. This removes dirt, grease, and grime, without leaving adhesion hindering residue. Ensuring that the surface is ready for rust treatment. Clean surfaces allow KBS products to work most effectively. Mix KBS Klean with warm water and scrub with a sponge or bristle brush. Rinse and dry thoroughly. Full instructions: https://www.kbs-coatings.com/kbs-klean-directions 3. Neutralize Rust with RustBlast For areas with existing rust and bare metal, RustBlast is applied. RustBlast penetrates and dissolves the rust to stop its progression and etches the metal for best adhesion of RustSeal. Spray on and keep wet for 30 minutes–2 hours depending on the amount of rust. Scrub intermittently with a Scotch Brite pad. Rinse and dry thoroughly. A whitish residue will remain; this prevents flash rust. Do not remove. Full instructions: https://www.kbs-coatings.com/rustblast-directions By combining these steps, you can neutralize rust and prepare the trailer for RustSeal. What is the Best Rust Inhibitor for Boat Trailers? Once rust is neutralized, applying a rust inhibitor is the next step. The KBS Coatings Ultimate Frame Coater Kit contains RustSeal, which is regarded as one of the best rust inhibitors for boat trailers. RustSeal is a rust preventive coating that provides long-lasting protection, creating a barrier for both rust-free and lightly rusted surfaces. This 1K moisture cured urethane coating is extremely hard, yet flexible. This helps to prevent chips, cracks, and peeling; keeping the metal sealed against moisture and oxygen. RustSeal can be applied to bare metal, treated rust, and well-adhered original paint that has been scuffed with 320 grit sandpaper, making it ideal for large or small repairs or preventative maintenance. How to Apply RustSeal Choose your application method: Brushing, rolling, or spraying; brushing is generally best for spot repairs, while spray equipment provides the smoothest finish. Optimal temperature: Apply between 55–82°F, avoiding rain or high humidity. Mix thoroughly: Stir from the bottom of the can to the top before use. Thinning/Reducing: When spraying, thinning is generally not required, but if needed, 5-10% is normally adequate. Apply in thin coats: At least three thin, even coats; multiple thin coats are better than a few thick ones. Re-coating: Once the previous coat is dry to the touch (2–6 hours), apply additional coats within 8 hours. Cure time: The area can be handled after 1 day, and full cure takes place in 7 days. Full instructions: https://www.kbs-coatings.com/rustseal-directions Top Coating RustSeal Top coating RustSeal is recommended since it isn’t intended as a final finish for surfaces exposed to direct sunlight. UV light may alter its color or sheen. Its rust protection remains fully effective. To protect against unwanted cosmetic changes, RustSeal can be top coated with any opaque paint system. KBS Top Coater paint is included for this purpose. KBS Top Coater is a superior 1K coating formulated to be brushed, rolled, or sprayed offering maximum coverage and professional-looking results. It is very high solids, does not run or sag, and gives at least twice the coverage of conventional paints. The paint doesn’t fade, is 100% UV stable and is available in 17 rich pigmented colors. Top Coater is available in aerosol and in cans. While aerosol provides the convenience of a spray, it does not build film thickness as quickly as the can version, requiring more coats. For top coating RustSeal on a boat trailer, we recommend using the canned version applied with spray equipment for the smoothest finish. Aerosol may be better for spot repairs. Prepare RustSeal for Top Coating Apply Top Coater once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-6 hours). Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff with 320 grit sandpaper, then apply Top Coater. Let the second or final coat of RustSeal fully cure (at least 24 hours), dust with Fusion Self-Etching Primer, let cure for 30 minutes, then apply Top Coater. How to Apply Top Coater Optimal temperature: Apply between 55–82°F, avoiding rain or high humidity. Mix thoroughly: Stir from the bottom of the can to the top before use. Thin: 10-20% as required. Use only KBS #1 Thinner or Xylene. Apply in thin coats: A single full coat can cover completely with full color depth. Re-coating: If desired, a second coat may be applied after 8 hours and before 7 days. Two thin coats are better than one heavy coat. Cure time: Full cure typically takes 4-7 days of air dry. Force drying can accelerate curing. Full instructions: https://www.kbs-coatings.com/kbs-top-coater-directions Cavity Coater: Inside and Out Rust Protection for Boat Trailers For hard-to-reach areas where RustSeal cannot be applied, such as inside trailer frame rails, Cavity Coater Aerosol is effective. Cavity Coater is a cavity wax and corrosion inhibiting coating that penetrates deeply to provide protection. It can be applied with the Cavity Spray Wand, a 48” hose with a 360° spray tip for complete coverage. How to Apply Cavity Coater Minimal surface preparation required; remove loose scaly rust and clean with KBS Klean where possible. Surface must be dry. Optimal temperature: 70-80°F. Shake extremely well before use and occasionally during application. Hold can 8-12 inches from surface. Apply a thin, even coat (1 mil thickness). Cover completely but do not over-saturate. Wait 10 minutes for coating to wick into seams and weld joints. Remove excess with a clean rag dampened with mineral spirits. For enclosed cavities, attach Cavity Wand to aerosol, insert, and withdraw at 1 foot per second, repeat for full coverage. Full instructions: https://www.kbs-coatings.com/cavity-coater-directions Summary: Prevent Rust and Save Money Rust is one of the most common and damaging issues for boat trailers. With proper care and the right products, you can stop existing rust, prevent future rust, and avoid costly repairs or replacements. Key takeaways: Understand that moist conditions, outdoor storage, and salt water accelerate rust. Remove and neutralize existing rust using KBS Klean and RustBlast. Protect the trailer with RustSeal, Top Coater, and Cavity Coater. Using the KBS Coatings Ultimate Frame Coater Kit is a reliable solution for boat trailer rust prevention. Investing time and effort in proper care ensures your trailer remains safe, reliable, and looking its best. With the right approach, rust will no longer be a threat to your investment.
- rust prevention
- rust protection
(and 2 more)
Tagged with:
Marine Paint Needs to Have Toughness, Flexibility, and Durability Marine environments can wreak havoc on metal and the paints they are finished with. Things like boat trailers, decks, hulls, masts, and storage lockers are susceptible to the moist and often salty conditions. Wear and tear can damage paint, exposing metal, and soon rust sets in. Without stopping rust, it causes damage that can be costly to repair or require replacement of the rusted part. To avoid damage the metal needs to be refinished immediately with marine paint. However, rust usually sets in before the job can be completed. So, what is the best way to refinish metal that is rusted? What needs to be considered when choosing a rustproof paint for marine use? Marine paint needs to separate air and moisture from the metal to avoid oxidation, the precursor to rust. To keep air and moisture away from metal the paint must bond strongly and be hard to avoid damage from wear and tear. Flexibility is another important quality marine paint needs to address. Flexibility allows the paint to remain bonded to the metal if it is dented, as well as when the metal expands and contracts. Durability is critical also to reduce the frequency of the metal needing to be refinished. UV stability is a primary concern as the paint will most likely have high exposure to the sun. To maintain an impenetrable barrier that will seal the metal away from air and moisture, marine paint ultimately must have toughness, flexibility, and durability to remain uncompromised by dings and dents to the metal, as well as the elements. KBS Coatings RustSeal performs well as a marine paint as it has the necessary toughness, flexibility, and durability needed to maintain an air and moisture proof seal with the metal. RustSeal is a single part, moisture cured, rust preventive coating. The formulation of the RustSeal makes it wholly non-porous and impervious to air, water, sea salt and chemicals. RustSeal is for use above or below the waterline and will protect metal that is underwater or exposed to constant high humidity. KBS Coatings' Advanced Cross-Linked Coatings Technology makes RustSeal both highly-durable and flexible. Its hardness helps to avoid damage from wear and tear, while its flexibility allows it to remain bonded to metal during expansion and contraction, or if it is dented. RustSeal will not crack, flake, or peel in marine environments. Check out THIS VIDEO demonstrating RustSeal’s durability and flexibility. RustSeal is user-friendly and can be brushed on, rolled on, or sprayed on. It flows out well and is self-leveling to provide a beautiful, smooth finish without brush marks. To achieve the best bond of RustSeal to metal, the surface needs to be properly prepared. Corrosion and organic contaminants need to be removed so that RustSeal can deeply penetrate and permanently adhere. This includes removing dirt, oil, grease and other contaminants. The surface also needs to have a texture, or etch, that allows the RustSeal to take hold. This preparation can be achieved by sand blasting. However, blasting with plastic, bead or soda media will not provide the amount of abrasion needed for direct RustSeal application. If the metal is not being sandblasted, KBS Coatings offers KBS Klean and KBS RustBlast for proper surface preparation. KBS Klean is a concentrated, water-based, biodegradable, and non-flammable formula that cleans the surface by removing dirt, grime, oils, lubricants, grease, waxes, scum, algae, and other contaminants. KBS Klean is applied after using 320 grit sandpaper, or a wire brush or wheel to remove any loose flakey rust. After the KBS Klean procedure is complete, it is time for KBS RustBlast. RustBlast is a powerful rust remover, zinc phosphate pre-primer, and metal etch. RustBlast dissolves rust, corrosion, metal oxides, and tarnish from most metal surfaces. Prior use of KBS Klean is important as the cleaner the surface is, the more effective RustBlast will be. RustBlast ultimately allows RustSeal to penetrate more deeply into pores in the metal to permanently seal and protect the surface. RustSeal is not intended for use as a final marine paint finish as long-term exposure to direct UV light will cause fading of the color and sheen. RustSeal’s guaranteed rust protective properties, however, will not degrade. To protect against unwanted cosmetic changes, RustSeal can be top coated with any opaque (solid color) paint system. A popular choice is KBS Coatings Top Coater, which is included in the KBS All-In-One Kit. This user-friendly all-inclusive kit consists of KBS Klean, RustBlast, RustSeal, KBS Top Coater and KBS #1 Thinner. KBS Top Coater is a single part, high solids paint that does not run or sag, and gives at least twice the coverage of conventional single part marine paint. Like RustSeal, KBS Top Coater can be brushed, rolled or sprayed on. Its self-leveling properties allow it flow out well, not show brush marks and provide professional looking results. KBS Top Coater is available in 16 colors. Marine environments can wreak havoc on metal and the marine paint it is finished with. KBS Coatings provides a solution to avoid rust with a tough, long lasting and durable barrier, while providing a beautiful and professional appearing finish. For more information on the KBS Coatings All-In-One Kit click HERE.
- marine paint
- marine coating
(and 2 more)
Tagged with:
Marine Paint Needs to Have Toughness, Flexibility, and Durability Marine environments can wreak havoc on metal and the paints they are finished with. Things like boat trailers, decks, hulls, masts, and storage lockers are susceptible to the moist and often salty conditions. Wear and tear can damage paint, exposing metal, and soon rust sets in. Without stopping rust, it causes damage that can be costly to repair or require replacement of the rusted part. To avoid damage the metal needs to be refinished immediately with marine paint. However, rust usually sets in before the job can be completed. So, what is the best way to refinish metal that is rusted? What needs to be considered when choosing a rustproof paint for marine use? Marine paint needs to separate air and moisture from the metal to avoid oxidation, the precursor to rust. To keep air and moisture away from metal the paint must bond strongly and be hard to avoid damage from wear and tear. Flexibility is another important quality marine paint needs to address. Flexibility allows the paint to remain bonded to the metal if it is dented, as well as when the metal expands and contracts. Durability is critical also to reduce the frequency of the metal needing to be refinished. UV stability is a primary concern as the paint will most likely have high exposure to the sun. To maintain an impenetrable barrier that will seal the metal away from air and moisture, marine paint ultimately must have toughness, flexibility and durability to remain uncompromised by dings and dents to the metal, as well as the elements. KBS Coatings RustSeal performs well as a marine paint as it has the necessary toughness, flexibility and durability needed to maintain an air and moisture proof seal with the metal. RustSeal is a single part, moisture cured rust preventive coating. The formulation of the paint makes it non-porous and impervious to air, water, sea salt and chemicals. RustSeal is for use above or below the waterline and will protect metal that is underwater or exposed to constant high humidity. KBS Coatings Advanced Cross-Linked Coatings Technology makes RustSeal both highly-durable and flexible. Its hardness helps to avoid damage from wear and tear, while its flexibility allows it to remain bonded to metal during expansion and contraction, or if it is dented. RustSeal won’t crack, flake or peel in marine environments. Check out this video demonstrating RustSeal's durability and flexibility. RustSeal is user-friendly and can be brushed on, rolled on, or sprayed on. It flows out well and is self-leveling to provide a beautiful, smooth finish without brush marks. The paint is available in at least 10 colors. To achieve the best bond of RustSeal to metal, the surface needs to be properly prepared. Corrosion and organic contaminants need to be removed so that RustSeal can deeply penetrate and permanently adhere. This includes removing dirt, oil, grease and other contaminants. The surface also needs to have a texture, or etch, that allows the RustSeal to take hold. This preparation can be achieved by sand blasting. However, blasting with plastic, bead or soda media will not provide the amount of abrasion needed for direct RustSeal application. If the metal is not being sandblasted, KBS offers KBS Klean and RustBlast for proper surface preparation. KBS Klean is a concentrated, water-based, biodegradable, and non-flammable formula that cleans the surface by removing dirt, grime, oils, lubricants, grease, waxes, scum, algae, and other contaminants. KBS Klean is applied after using 320 grit sandpaper, or a wire brush or wheel to remove any loose flakey rust. After the KBS Klean procedure is complete, it is time for RustBlast. RustBlast is a powerful rust remover, zinc phosphate pre-primer, and metal etch. RustBlast dissolves rust, corrosion, metal oxides, and tarnish from most metal surfaces. Prior use of KBS Klean is important as the cleaner the surface is, the more effective RustBlast will be. RustBlast ultimately allows RustSeal to penetrate more deeply into pores in the metal to permanently seal and protect the surface. RustSeal is not intended for use as a final marine paint finish as long-term exposure to direct UV light will cause fading of the color and sheen. RustSeal’s guaranteed rust protective properties, however, will not degrade. To protect against unwanted cosmetic changes, RustSeal can be top coated with any opaque (solid color) paint system. A popular choice is KBS Coatings Top Coater, which is included in the KBS All-In-One Kit. This user-friendly all-inclusive kit consists of KBS Klean, RustBlast, RustSeal, Top Coater and KBS #1 Thinner. KBS Top Coater is a single part, high solids paint that does not run or sag, and gives at least twice the coverage of conventional single part marine paint. Like RustSeal, KBS Top Coater can be brushed, rolled or sprayed on. Its self-leveling properties allow it flow out well, not show brush marks and provide professional looking results. KBS Top Coater is available in at least 16 colors. Marine environments can wreak havoc on metal and the marine paint it is finished with. KBS Coatings provides a solution to avoid rust with a tough, long lasting and durable barrier, while providing a beautiful and professional appearing finish. For more information on the KBS Coatings All-In-One Kit click HERE.
- marine paint
- rust prevention
(and 2 more)
Tagged with:
