Showing results for tags 'motor paint'.
As you can see, Motor Coater is formulated to make it easy to achieve stunning, professional-looking results when painting you engine. Motor Coater colors are an exact match for the original color offering a rich, deep factory finish. Motor Coater is very durable protecting your engine from chips, chemicals, and heat. Motor Coater features advanced resin technology for heat dissipation and gloss retention. Motor Coater is an incredible exterior grade coating that is UV stable and will not discolor, chalk, or fade when exposed to sunlight and the elements. Motor Coater resists temperatures up to 500F intermittently and produces a professional finish that won't blister, flake, crack, or peel. Learn More about Motor Coater here -> https://www.kbs-coatings.com/motor-coater
- engine paint
- motor paint
(and 2 more)
Tagged with:
Motor Coater from KBS Coatings is one of the most popular engine paints on the market and is used by auto restorers all over the world. Motor Coater is very easy to apply, offers superb coverage and yields a self-leveling professional looking finish brushed or sprayed. These engine enamels provide deep, rich pigmented colors for excellent coverage. Motor Coater is very easy to brush out and looks like it has been sprayed when brushed out but you can also get Motor Coater in the convenience of an aerosol can on most colors. Motor Coater is a very durable coating protecting your engine from chips, chemicals and heat. Your engine coated with Motor Coater will be a show stopper at this DIY price!
- engine paint
- engine enamel
(and 2 more)
Tagged with:
“I sprayed 3 coats of KBS Gloss Black Motor Coater allowing each coat to fully cure and scuffing with a red scotch brite pad between coats to get a fairly smooth surface. Finally, I sprayed 3 coats of KBS Diamond Clear. I’m super happy with the results!” -Jamie P
- engine paint
- motor coater
(and 1 more)
Tagged with:
