Showing results for tags 'fuel pump'.
    • KBS MAXX Clear
    • KBS Top Coater 1K Aerosol
  1. Video shows old style tank, but what about newer style tanks with fuel pump inside tank and larger openings. I assume I remove all parts from inside the tank before the 3 steps KBS Kleen, RustBlast, and Tank sealer, correct. Suggestions for plugging such large openings? Regarding pipe cleaners for plugging small openings Do you mean that the tank sealer is so viscous or thick or has such surface tension or some other property that the pipe cleaners block the tank sealer from adhering to the inside of tubing which is sealed by inserting pipe cleansers long ways into the tubing, using as many as it takes to fill the opening on the inside or the tank prior to applying the sealer? I see to wait until sealer is tacky and now longer dripping or running to remove the pipe cleaners, correct?
