KBS Coatings Posted January 17, 2008 Report Share Posted January 17, 2008 If you can spray on and rinse off the cleaner and prep, then drain and let the tank dry thoroughly, then brush, spray, or roll on the sealer, then sure it will work fine. Give us a call if you need to discuss the job further. More good information here: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html Quote Link to comment Share on other sites More sharing options...
