metal fence
KBS Coatings
The first step would be to clean the fence. You will want to use the AquaKlean to accomplish that.
AquaKlean is here: http://www.kbs-coatings.com/KBS-AquaKlean_p_1-27.html
AquaKlean application information can be found here: http://www.kbs-coatings.com/AquaKlean-Information-Instructions_ep_36-1.html
The second step is the etch the metal fence. You will want to use RustBlast to accomplish that.
RustBlast is here: http://www.kbs-coatings.com/KBS-RustBlast_p_1-29.html
RustBlast application information can be found here: http://www.kbs-coatings.com/RustBlast-I ... _37-1.html
The next step would be to seal the fence with RustSeal. You will want to apply two coats.
RustSeal is here: http://www.kbs-coatings.com/KBS-RustSeal_p_2-18.html
RustSeal application information can be found here: http://www.kbs-coatings.com/RustSeal-In ... _38-1.html
The last step would be to topcoat the RustSeal with a UV stable topcoat. The RustSeal will chalk and fade with consistent and prolonged exposure to UV rays, so you will probably want to use a good exterior grade opaque topcoat in your color of choice to go over the RustSeal. The best way to topcoat the RustSeal is by getting your topcoat applied within 4-12 hours of your second coat of RustSeal. If you are unable to do that, you can also use the KBS Fusion Self-Etching Primer which will allow your topcoat to adhere to completely cured RustSeal.
You can find the KBS Fusion SEP here: http://www.kbs-coatings.com/KBS-Fusion--Self-Etching-Primer_p_6-28.html
