Zander Posted July 24, 2021 Report Share Posted July 24, 2021 Manual reads Fusion can be applied directly over Rust Seal after 24 hours, but also mentions for older coatings sanding is required. After what time Rust Seal is considered too old for the direct Fusion application ? Quote Link to comment Share on other sites More sharing options...
KBS Coatings Posted July 26, 2021 Report Share Posted July 26, 2021 If RustSeal is fully cured and the surface is clean, you can simply use Fusion SEP. The sanding is for a worst-case scenario and 99% of the time, sanding is not needed. Please let us know if that helps and if you have any additional questions. Quote Link to comment Share on other sites More sharing options...
