July 20, 20188 yr comment_4262 Is rust seal better to use than a 2k epoxy primer?and if so am I to treat it like I would a epoxy,meaning ,paint the bare metal with rust seal and than scuff ,than spray couple coats of 2k high build let it cure and do my sanding?and how does rust seal work with bondo?do you paint rust seal first than bondo ,sand than 2k high over that than sand is there any particular order?thank you Link to comment https://success.kbs-coatings.com/topic/2294-2k-highbuild-primers-and-rust-seal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 21, 20188 yr comment_4263 Yes, RustSeal is much better at preventing rust than a standard 2K Epoxy Primer. Clean the surface well first with KBS Klean and then etch well with RustBlast. There are three effective ways to topcoat RustSeal (with BlackTop, KBS Top Coater, KBS MAXX, other solid color top coat paints, 1K Primers or 2K Primers) effectively so that the coatings bond and fuse together. Please choose the one that works for your project. 1) Apply your top coat once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-6 hours depending on temperature and humidity). 2) Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff the RustSeal with 320 grit, then apply your top coat. 3) Let the second or final coat of RustSeal fully cure (at least 24 hours), dust the RustSeal with Fusion Self-Etching Primer, let the Fusion cure for 30 minutes, then apply your top coat. As for Bondo, prep and then seal the surface first with RustSeal and then apply your Bondo following the guidelines above for applying a top coat over RustSeal. Doing this allows the RustSeal to seal up the surface and prevent the Bondo from popping off. Please carefully review the complete RustSeal Directions and let us know if you have any additional questions. Thanks for contacting KBS Coatings! Link to comment https://success.kbs-coatings.com/topic/2294-2k-highbuild-primers-and-rust-seal/#findComment-4263 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 21, 20188 yr Author comment_4264 thanks for responding,Im having good results using your products so far,for me the grey rust seal is laying better than the satin black did,could have been the humidity but works great none the less. Link to comment https://success.kbs-coatings.com/topic/2294-2k-highbuild-primers-and-rust-seal/#findComment-4264 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 21, 20188 yr comment_4265 Yes, RustSeal is a moisture cured urethane so the humidity and temperature will dictate how the RustSeal cures. We appreciate your kind words. Thanks for choosing KBS Coatings. Link to comment https://success.kbs-coatings.com/topic/2294-2k-highbuild-primers-and-rust-seal/#findComment-4265 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
February 4, 20224 yr comment_5423 Can you use a stronger phosphoric acid solution before the Rust Blast in order to remove/convert larger amounts of rust on a car/truck frame? Was thinking of using Rust Kutter to convert rust, washing it off, and then using the Rust Blast to etch the metal with zinc phosphate to prepare for the applicaiton of the KBS Rust Seal. Link to comment https://success.kbs-coatings.com/topic/2294-2k-highbuild-primers-and-rust-seal/#findComment-5423 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 17Aug 17 comment_10524 Updated for 2026: The three ways to topcoat RustSeal with 2K primers.1) Apply your primer or topcoat once the final coat of RustSeal is dry to the touch and does not leave a fingerprint, usually 3-6 hours depending on temperature and humidity.2) Let RustSeal fully cure at least 24 hours, scuff with 320 grit, then apply your primer or topcoat.3) Let RustSeal fully cure, then apply a dust coat of Fusion Self-Etch Primer before your topcoat.Full directions: https://kbs-coatings.com/rustseal-directionsFusion Self-Etch Primer: https://kbs-coatings.com/fusion-self-etch-primer Link to comment https://success.kbs-coatings.com/topic/2294-2k-highbuild-primers-and-rust-seal/#findComment-10524 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
