Storing issues
Bsud
I've been trying to figure out the best way to store between uses. I've been using Mason jar and putting a zip lock bag over it and then the lid. But even then the lid is still getting stuck to where I have to pry the lid off. Any suggestions as to what to do?
From what you are describing, it sounds like you are getting DiamondFinish Clear on the rim of the jar or on the inside of the lid. This seems to be the only way it could get stuck. To help prevent the lid getting stuck, clean off the rim of the jar and the lid of the jar with KBS #1 Thinner before putting the lid back on. That will prevent the lid from getting stuck.
Also, be sure to use KBS Paint Saver to preserve the DiamondFinish Clear in the jar or can. When storing DiamondFinish Clear, hold container lid and plastic wrap closely above container and spray KBS Paint Saver towards side of the container to avoid splashing. Spray KBS Paint Saver two seconds for quarts or less and four seconds for gallons. KBS Paint Saver prevents oxygen and moisture damage and extends storage times of DiamondFinish Clear.
Please let us know if that helps and if we can assist you in any other way.
