September 9, 201610 yr comment_3871 Can I put Bed Renu over Rust Seal? If so, how long do I have to wait to paint? Link to comment https://success.kbs-coatings.com/topic/2109-bed-renu-over-rustseal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 26, 201610 yr comment_3918 Yes, you can absolutely paint KBS Bed Renu over RustSeal. There are three effective ways to topcoat RustSeal with KBS Bed Renu so that the coatings bond and fuse together. Please choose the one that works for your project. 1) Apply the KBS Bed Renu once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-6 hours depending on temperature and humidity). 2) Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff the RustSeal with 320 grit, then apply KBS Bed Renu. 3) Let the second or final coat of RustSeal fully cure (at least 24 hours), dust the RustSeal with Fusion Self-Etching Primer, let the Fusion cure for 30 minutes, then apply KBS Bed Renu. Please let know if that helps you out and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2109-bed-renu-over-rustseal/#findComment-3918 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
