Guest Posted July 5, 2016 Report Share Posted July 5, 2016 I want to seal my gas tank with your sealer but I have a question. I have a chain that is connected to my gas cap. What do you recommend I should do with the chain? I don't want the chain to get coated with KBS Tank Sealer. Quote Link to comment Share on other sites More sharing options...
KBS Coatings Posted July 6, 2016 Report Share Posted July 6, 2016 It would be best to take some needle nose pliers and detach the chain while you do the Tank Sealer 3-Step Process if you do not want the chain to get coated. After the Tank Sealer is cured inside the tank, you can attached the chain again using the needle nose pliers. Please check out the Tank Sealer Directions and let us know if you have any additional questions. Quote Link to comment Share on other sites More sharing options...
