Guest Posted June 23, 2016 Report Share Posted June 23, 2016 I have some railings that are powder coated. I would like to paint your Diamond Finish over the powder coating. Will this work? Quote Link to comment Share on other sites More sharing options...
KBS Coatings Posted June 23, 2016 Report Share Posted June 23, 2016 Yes. You can absolutely clear over a powder coated surface. For surface preparation, scuff the surface with 300 grit and then clean the surface with KBS Klean. Allow to dry and then apply a minimum of 2-3 thin, covering coats of DiamondFinish Clear. Please check out the DiamondFinish Clear Directions and let us know if you have any additional questions. Quote Link to comment Share on other sites More sharing options...
