Guest Posted June 13, 2016 Report Share Posted June 13, 2016 I noticed on your Tank Sealer directions it says you can use duct tape or electrical tape to provide a sufficient seal to allow me to rotate, turn and invert the tank without the sealer spilling all over the place. Can I use Duct tape to seal up the hole when I use your KBS Strip so it won't spill all over? Quote Link to comment Share on other sites More sharing options...
KBS Coatings Posted June 13, 2016 Report Share Posted June 13, 2016 We do not recommend using duct tape when stripping the inside of your tank because the KBS Strip will usually eat through any adhesives on the tape. As always, extra care needs to be taken when using KBS Strip to avoid contact with exterior paint of a tank. KBS Strip is a powerful paint remover and WILL INDEED remove exterior paint on gas tanks. Please review the Tank Sealer Directions which covers stripping the inside of the tank (if needed) and let us know if you have any additional questions. Quote Link to comment Share on other sites More sharing options...
