Guest Posted May 9, 2016 Report Share Posted May 9, 2016 I've painted a lot of Rust Seal but never your Diamond Finish. How long do I wait to paint between coats? Quote Link to comment Share on other sites More sharing options...
KBS Coatings Posted May 12, 2016 Report Share Posted May 12, 2016 For DiamondFinish Clear, re-coating can be done once the first or consecutive coat is dry-to-touch and does not leave a fingerprint. Remember to clean your spray gun immediately after using DiamondFinish Clear. Always apply coats consecutively within 6 hours of each coat curing. Average cure times are 1-2 hours, depending on humidity levels. Please check out the Complete DiamondFinish Clear Directions and let us know if you have any additional questions. Quote Link to comment Share on other sites More sharing options...
Joseph Harrison Posted May 29, 2016 Report Share Posted May 29, 2016 Do you make a urethane top coating with color? I need the use of a product that is not effected by high humid air. I live next to salt water. In this location damp air is always a problem. Please advise me on the best method using KBS coatings ending with a good looking finish. Too much moisture in the air I find it imposable to end up with a good finish. Help is needed here, Thank You…. Joe Harrs. Quote Link to comment Share on other sites More sharing options...
KBS Coatings Posted May 31, 2016 Report Share Posted May 31, 2016 KBS MAXX is ideal for your application. What exactly are your coating? Steps for ideal application: 1) Clean the surface with KBS Klean 2) Etch the surface with RustBlast 3) Coat the surface with 2 thin,covering coats of RustSeal 4) Top coat the RustSeal with KBS MAXX Please check out the KBS MAXX Directions and the RustSeal Directions and let us know if you have any additional questions. We are here to help. Quote Link to comment Share on other sites More sharing options...
