Guest Posted May 4, 2016 Report Share Posted May 4, 2016 I'm getting ready to paint a wood table with Rust Seal. I was wondering if the coverage is the same for wood as it is metal? Any help would be much appreciated. Thank you! Quote Link to comment Share on other sites More sharing options...
KBS Coatings Posted May 6, 2016 Report Share Posted May 6, 2016 Because wood is typically more porous than metal, you can expect to get slightly less coverage for a wooden surface. 1 gallon of RustSeal will typically put 2 coats on 200 square feet of a metal surface and 166 square feet for 2 coats on a wood surface. As always, material losses during mixing and application will vary and must be taken into consideration. Please check out the RustSeal Directions and let us know if you have any additional questions. Quote Link to comment Share on other sites More sharing options...
