althezenman Posted April 8, 2016 Report Share Posted April 8, 2016 I am sorry if this has been covered already. I am using Rustseal as a preventative measure on a motorcycle frame that only has a few small spots of rust, overall it is in perfect condition. I want to achieve a powdercoat like finish with little orange peel and high gloss. Two Questions. 1.Before using KBS Klean and RustBlast, can I sand up to 400 Grit or should I stop with 220 or 320? 2. Will a 2k Clear increase the overall gloss or is there a general consensus that it is overkill in this situation? Thanks Quote Link to comment Share on other sites More sharing options...
KBS Coatings Posted April 11, 2016 Report Share Posted April 11, 2016 Answers 1) 220 or 320 would be best for developing an ideal anchor pattern for the RustSeal to stick once the surface has been prepped. 2) We do not recommend clear coating over RustSeal. A clear topcoat cannot provide the needed UV protection. Please let us know if that helps and if you have any additional questions. Quote Link to comment Share on other sites More sharing options...
