Rust Seal
That is a great question. Usually hard to reach areas are extremely hard to prep correctly making RustSeal not always the best choice. But if you want to spray RustSeal in to cavities and hard to reach areas, our UnderSeal Spray Gun is designed to get coatings in to hard to reach areas. The UnderSeal Spray Gun has a working pressure range of 87 to 145 PSI and is reusable if the gun is flushed immediately when finished with KBS #1 Thinner.
The reason we developed Cavity Coater is precisely for your application because it is the perfect solution for hard to reach areas that are prone to rusting. The Cavity Coater  prevents rust in areas that simply can not be prepped because it is extremely surface tolerant. It sticks even when the surface is dirty.
Please review the Cavity Coater Directions and let us know if you have any additional questions.
