May 25, 201016 yr comment_2051 Hi, I recently used your auto tank 3 part sealer kit and followed the instructions very closely. However it is always humid here so maybe that is the reason I have 4 small very hard bubbles on the bottom. My question is will that cause any problems down the line because I really don't have time to wait to reseal the tank. There is also a small flat cylinder type device which the metal tubing goes to, I'm guessing it's the fuel return but I'm not a mechanic. My question for that is could the sealer have damaged it? I cannot feel any openings on it so all I did was sand the rust off it, cleaned it with the first 2 parts of the kit. Then covered it with duct tape while I sealed. Thanks in advance Link to comment https://success.kbs-coatings.com/topic/1420-just-a-few-hard-bubbles/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 25, 201016 yr comment_2353 As long as the bubbles are hard and solid, you should be fine. Maybe try poking them with a coat hanger to see how hard and solid they are. I do not see why the dealer could have damaged your flat cylinder type device. Why do you think it may have damaged it? Link to comment https://success.kbs-coatings.com/topic/1420-just-a-few-hard-bubbles/#findComment-2353 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 25, 201016 yr Author comment_2354 I was actually wondering what it was. I'm guessing it was for the fuel return, but I couldn't feel any holes for the fuel to make it back into the tank. However I cant see it so I really don't have a clue what it's for. So I guess my question was if anyone knew what that could be? Link to comment https://success.kbs-coatings.com/topic/1420-just-a-few-hard-bubbles/#findComment-2354 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 25, 201016 yr comment_2355 I am honestly not able to visualize a flat cylinder, so I have no idea. But, maybe someone else does and will chime in. Or maybe you could speak with a local mechanic and they could let you know what that is?.. Link to comment https://success.kbs-coatings.com/topic/1420-just-a-few-hard-bubbles/#findComment-2355 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 26, 201016 yr Author comment_2356 O.k. thanks for your help. The bubbles are solid, I look forward to getting the truck running. Link to comment https://success.kbs-coatings.com/topic/1420-just-a-few-hard-bubbles/#findComment-2356 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 26, 201016 yr comment_2357 Sounds Great! Please let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1420-just-a-few-hard-bubbles/#findComment-2357 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
