May 14, 201016 yr comment_2048 G'day, I'm looking to coat a landcruiser gearbox, transfer case and bellhousing, is the rust seal (along with rust blast and aqua klean) compatible with cast aluminium? Plus, would you recommend a top coat over the rust seal since the gearbox does cop a fair bit of abuse? Cheers, Hurell Link to comment https://success.kbs-coatings.com/topic/1417-painting-gearbox-and-transfer-case/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 14, 201016 yr comment_2350 Yes. All of those products are compatible with Aluminum. Yes. It does sound like a top coat would be a good idea for your application. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1417-painting-gearbox-and-transfer-case/#findComment-2350 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
