November 5, 200916 yr comment_2015 Hi, this is the 2nd tank I have sealed using your product, 1st one great, as time was not an issue with this tank, each stage was carried out to the letter, the tank has now been painted & yesterday was filled with gas, this morning there is a tiny bubble at the bottom rear of the tank, about the size of a pin head, I fear this is the start of a leak, what can I do as the tank is finished with base coat & 2 pack clear? Roy. Link to comment https://success.kbs-coatings.com/topic/1384-tank-sealer-bubbles/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 5, 200916 yr comment_2270 Where is the Tiny Bubble? On the Outside or the Inside of the tank? Link to comment https://success.kbs-coatings.com/topic/1384-tank-sealer-bubbles/#findComment-2270 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 5, 200916 yr Author comment_2272 It's now plural, the bubbles are showing on the outside of the tank, low down at the rear. Link to comment https://success.kbs-coatings.com/topic/1384-tank-sealer-bubbles/#findComment-2272 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 6, 200916 yr comment_2273 It sounds like you did not get all of the holes patched or you did not get the entire inside of the tank coated. You will want to strip out the Gold Standard Tank Sealer with the KBS Strip. Then you will want to patch your holes using the BackBone Reinforcing Mesh or the NuMetal Epoxy Putty. Once you have the holes patches, you will do the KBS 3 Step Tank Sealing System. You can find complete instructions for the Gold Standard Gas Tank Sealer here: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with Tank Sealer here: http://www.kbs-coatings.com/fix-it-guide-tank-sealer.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find Tank Sealer Flow Charts here: http://www.kbs-coatings.com/Flow-Chart--Tank-Sealer_ep_88-1.html Link to comment https://success.kbs-coatings.com/topic/1384-tank-sealer-bubbles/#findComment-2273 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 4, 200916 yr Author comment_2293 I know I have to use the KBS strip, but you say to plug the pin holes with the epoxy putty, these holes are so small as to only be visible with a magnifying glass, how do I fill them & still get a smooth paint finish on the outside of the tank? Link to comment https://success.kbs-coatings.com/topic/1384-tank-sealer-bubbles/#findComment-2293 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 9, 200916 yr comment_2295 In that case, you could paint those holes with RustSeal on the outside and then seal the inside. And you could also use the BackBone Reinforcing Mesh to solidify the area with the holes. http://www.kbs-coatings.com/KBS-BackBone-Reinforcing-Mesh_p_22.html Link to comment https://success.kbs-coatings.com/topic/1384-tank-sealer-bubbles/#findComment-2295 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
