August 4, 200917 yr comment_2001 first of all i have had great success with most products used from KBS the biggest issue i have been having is that i get alot of runs in some irregualr shaped parts im sure i can avoid that by brushing it on alot thinner and not as heavy the opther thing is that i see alot of air bubles of some sort on few areas of the material after dried. what causes this? needs to be stired more? thined out or reduced? its making my restoration look of poor quality when its really not, please give me some input on this so i can correct the problem. i can include pictures if needwed. Link to comment https://success.kbs-coatings.com/topic/1370-small-air-bubles-in-runs/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 5, 200917 yr comment_2246 As always, pictures help but, it sounds like you're just applying the RustSeal a little too heavy. As with most all paints, they are best applied in multiple thin coats and not heavy coats as you'll have varying rates of curing. When applied thin, the film thickness cures through and through all at once. You can allow these areas to cure completely sand them smooth and reapply another coat. Also a few questions: What color are you using? What's the temperature and/or humidity where you are? Link to comment https://success.kbs-coatings.com/topic/1370-small-air-bubles-in-runs/#findComment-2246 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 2, 201016 yr comment_2359 I am having the same problem and I think it must be temperature, humidity, and thickness (User error and picky product). I am going to try again. I did not know there would be such a learning curve with this stuff. So far I am not impressed with the trouble you have to go through just to get a bubble coated finish. (Followed all prep steps) Rattle cans may not last as long but they sure are a lot easier and cost effective. I am not giving up yet but I am not sold yet. I live in TX and it is hot and humid most of the time. I guess I can forget about spraying outside in June. Yesterday was 97 and the humidity was high. I am painting inside wearing a respirator under an A/C last night with a brush. I spread the paint as thin as thin can be. When turning off the light to go in the bubbles were there in the film. I expect them to be there when I get home tonight. I hope not but so far that is how it is going with this stuff. Link to comment https://success.kbs-coatings.com/topic/1370-small-air-bubles-in-runs/#findComment-2359 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 3, 201016 yr comment_2361 Yep, popped bubbles still there. I will try again on something else and spread it so thin it will take 3 coats to cover. I guess this may work. If it does not I will give up and not use this anymore. Link to comment https://success.kbs-coatings.com/topic/1370-small-air-bubles-in-runs/#findComment-2361 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 4, 201016 yr comment_2362 We always tell our customers in high humidity areas over summer that they should thin at least 10% and keep thinning until it works. Apply thin covering coats. You can also just work in the cool of the morning or evening. BUT you MUST THIN IT in those conditions. Link to comment https://success.kbs-coatings.com/topic/1370-small-air-bubles-in-runs/#findComment-2362 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
