June 16, 200917 yr comment_1989 Hello, I just ordered a quart of KBS rustseal in iron oxide. My plan is to use this to seal the internal casting surfaces of an outboard marine engine. The internal parts of the engine were originally painted with a ferrous chrome primer - of course which, is no longer available. After a long search for a substitute paint, I found your product. My question is weather the paint will withstand application to water jacket surfaces that will be constantly wet with water up to 180 degrees F. The paint will also be applied to the crankcases where raw gasoline/oil vapor (2 cycle) will constantly wash over it. These surfaces will all be media blasted with Aluminum Oxide - after which will be cleaned with detergent, washed with hot water, and allowed to dry completely. I don't plan to use any other prep before using your product. Is this acceptable? Also, not sure if I will apply with brush or use my air pot. I did purchase your thinner also. Lastly, what solvent is best used for cleaning my spray gun after use of your product? Thank You Link to comment https://success.kbs-coatings.com/topic/1358-painting-internal-engine-parts/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 17, 200917 yr comment_2224 "My question is weather the paint will withstand application to water jacket surfaces that will be constantly wet with water up to 180 degrees F." Yes. That should be fine. "These surfaces will all be media blasted with Aluminum Oxide - after which will be cleaned with detergent, washed with hot water, and allowed to dry completely. I don't plan to use any other prep before using your product. Is this acceptable?" As long as there is a sufficient surface profile for adhesion, this will be fine. DO NOT use an solvent-based cleaners. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html Link to comment https://success.kbs-coatings.com/topic/1358-painting-internal-engine-parts/#findComment-2224 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 17, 200917 yr Author comment_2225 The aluminum isn't super smooth as it is cast. I think it will have plenty of "tooth" for the paint. Thanks for the quick reply. Link to comment https://success.kbs-coatings.com/topic/1358-painting-internal-engine-parts/#findComment-2225 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 17, 200917 yr comment_2226 Your welcome. Please let us know if you have any other questions. Link to comment https://success.kbs-coatings.com/topic/1358-painting-internal-engine-parts/#findComment-2226 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
