JWPOORE Posted April 21, 2009 Report Share Posted April 21, 2009 Should I apply Rust seal the same way to the painted, non rusted areas and top coat with with Satin Black like planned in the rusted areas? The painted surfaces to not need to be etched with the RustBlast, but otherwise, it is the same. If the paint is super smooth, it would be a good idea to sand it. Will the Rust Seal adhere to the painted areas with no rust? If the paint is super smooth, it would be a good idea to sand it. What prep would be needed in the non rusted areas in order for the Rust Seal/Top Coat to adhere properly? You will want to use the AquaKlean and RustBlast to prep those areas. You can find complete instructions here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html Quote Link to comment Share on other sites More sharing options...
