Dave Posted March 7, 2009 Report Posted March 7, 2009 If you apply RustSeal under the seam sealer it's not as necessary to paint over, however that would be best as it helps in sealing the entire surface. Just be sure to use a sealer that's labeled "paintable" and you should be good. Quote
