347sixtyseven Posted February 20, 2009 Report Share Posted February 20, 2009 Gary, Yep, sometimes you'll run into areas such as this. If you have access, this underseal gun works great: http://www.kbs-coatings.com/Underseal-Spray-Gun-amp-Probe_p_37.html You can use it to apply the RustSeal into that area. The RustSeal will run in and seal that area up. Otherwise you may be able to pour some in and roll or tip the cowl to spread out the RustSeal that way. Quote Link to comment Share on other sites More sharing options...
