KBS Coatings Posted January 7, 2009 Report Posted January 7, 2009 You can mix colors however, I'm not sure mixing green and silver will give you a "metallic" green as the green in an opaque color...but you can try. Clear can be applied to an alloy engine, however RustSeal clear may yellow with UV exposure. We will be introducing a new single pak clear soon that would be better for that type of application. Ideally you want RustSeal applied to the bare metal for the best rust protection. But it can be applied over existing paints providing they are sticking well, then abraded so that the RustSeal can bond to it. You can apply to the outside of the radiator...inside would be another issue as it may block coolant flow in some areas. Where are you located? Quote
