FrankV Posted December 18, 2008 Report Share Posted December 18, 2008 You can try it, however BlackTop is a moisture cured coating and any moisture content in the flattening agent may cause the BlackTop to cure too quickly. I would try a test sample first to see if it already is flat enough for you. Quote Link to comment Share on other sites More sharing options...
