KBS Coatings Posted December 1, 2008 Report Share Posted December 1, 2008 No video available yet on that topic, however we do have that on our schedule for early next year. Use a good grade paint stripper which contains methylene chloride. Mask off the tank (if it's already painted) and pour in the stripper and wet the entire interior surface. Occasionally rotate the tank allowing the stripper to rest on each section of the tank for at least 10 minutes. pour out the stripper, but save it. Rinse out the tank well with water and take a look inside. Repeat as necessary. Once the old sealer is out, proceed with the KBS Sealer Kit process. You can find KBS Strip here: http://www.kbs-coatings.com/kbs-strip.html You can find KBS Strip Instructions here: http://www.kbs-coatings.com/kbs-strip-info.html Quote Link to comment Share on other sites More sharing options...
