KBS Coatings Posted September 22, 2008 Report Share Posted September 22, 2008 It sounds like that tank had a previous sealer that is failing. That old sealer needs to stripped using KBS Strip. You can find KBS Strip here: http://www.kbs-coatings.com/kbs-strip.html You can find KBS Strip Instructions here: http://www.kbs-coatings.com/kbs-strip-info.html After stripping, follow the KBS system for sealing that tank. Avoid applying the sealer to the plastic area as much as possible. You can find complete instructions for the Gold Standard Gas Tank Sealer here: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html Quote Link to comment Share on other sites More sharing options...
