KBS Coatings Posted August 27, 2008 Report Share Posted August 27, 2008 Yes that would work. Before dividing the Pint of Tank Sealer, make sure you stir it well first. Also, recap the can right away and use plastic wrap to avoid permanently sealing the lid. I would try & use the Tank Sealer in a reasonable amount of time. The shelf life of an opened can be prolonged by storing it in a cool dry place.Also, you do understand not to try & save any drained sealer as it has already started the curing process. Tank Sealer: http://www.kbs-coatings.com/Tank-Sealers_c_7-1-0.html Tank Sealer Instructions: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html Quote Link to comment Share on other sites More sharing options...
