Posted
We have a great kit in our Frame Coater Kit which gives you enough AquaKlean, RustBlast, and RustSeal paint to coat about 50 sq feet with two coats. It's enough to do a full size car or truck frame. The kit also includes some brushes and gloves too!You'll need to topcoat only the areas that will be exposed to direct prolonged sunlight, and even those areas will only turn to a flat finish over time. If you decide you want to topcoat some or all areas, you can topcoat with any paint of your choice between the 2nd thru 8th hour after applying RustSeal and you should get good adhesion. Or use our All-In-One Kit which includes everything in the Frame Coater Kit plus...BlackTop topcoat and some #1 Thinner should you decide to spray our coatings.
Here's a link to both: http://www.kbs-coatings.com/Restoration-Kits_c_8-1-0.html
