Temporary fix?
rc51
I guess my question would be how large is this area or defect in these tanks? Is it just a hairline crack or pin hole? If so, then applied correctly, it is a permanent cure. If this is a defect which in time will continue to get worse due to vibration, then welding may need to be done.
You would not need any aircraft material to remove the stripper, just use a good quality paint stripper containing methylene chloride found at most hardware stores.
