KBS Coatings Posted May 26, 2008 Report Share Posted May 26, 2008 OK, thanks for that information. We've pulled a quart of that batch number, gave it a good stir, and cannot duplicate the issues you mentioned. It is black black. Sounds like a stirring issue. Over time and temperature fluctuations, the resins and pigments in all coatings have a tendency to settle and/or separate and must be stirred well while using a lifting action. This should be done for a minimum of two minutes with any coating to get a uniform appearance. The conditions you stated were fine and not extreme by any means. The fact that the high gloss appears just confirms the stirring issue. Quote Link to comment Share on other sites More sharing options...
