durable waterproof coating
I have used your products on metal - great stuff! Now I need a paint to apply to wood to provide a very durable waterproof coating. Will be exposed to high humidity and moisture - not water as such. Do you a recommendation. Thanks for your help.
  • Author
Thank you for the feedback. We appreciate it.
The first thing with wood is to make sure it is extremely dry.
Clean any previously painted surfaces with AquaKlean. http://www.kbs-coatings.com/KBS-AquaKlean_p_1-27.html
Sand any previously painted surfaces with 300 grit.
Apply 3 coats of RustSeal (because it is a very humid environment ... otherwise 2 coats would be fine.) http://www.kbs-coatings.com/KBS-RustSeal_p_2-18.html
Topcoat with a UV stable topcoat (if applicable).
Complete instructions can be found here: http://www.kbs-coatings.com/RustSeal-In ... _38-1.html
Please let us know if this helps and if you have any additional questions.
