RustSeal on Bath Tub
This is going to sound like a crazy question, but... Can Rust Seal be used as a coating for bath tubs? If so I would assume the tub would need to be cleaned, scuffed and primer applied first.
  • Author
You can use RustSeal on your bathtub. However, I would also highly recommend applying a UV Stable topcoat.
Here is a quick overview:
Clean the surface with KBS Klean.
Give your previous coating a sand with 300 grit.
Apply 2 coats of RustSeal roughly 3-8 hours apart.
Then apply your top coat within 3-8 hours.
Please check out the RustSeal Directions and let us know if you have any additional questions.
