Showing results for tags 'weld seams'.
    • Announcements
Found 2 results
  1. I just welded a rear quarter panel on and was thinking of using this as a seam sealer to cover the weld seams and then sand it smooth. Would it be best to paint RustSeal first, then push this epoxy into the seam sand it smooth then top coat with another coat of RustSeal for protection?
  2. I want to protect the weld seams in my fuel tank from rust. Can the rust sealer be used internally on a tank? If not, can the tank sealer be painted on the seals inside the tank instead of lining the entire tank? A family member keeps discouraging me from DIY fuel sealers as he had a friend that used one and came apart clogging the fuel system. Both these guys are mechanical engineers that work in Aerospace... so it's hard to discount their advice. What advice can you give for my application and perhaps this family member?
